ex bakes
Old Mar 20, 2005 | 04:59 PM
Dirtpig's Avatar
Default ex bakes
How much trouble is it to change rear brake pads on a 02 400ex..........any help would be appreciated
Old Mar 20, 2005 | 07:23 PM
Dirtpig's Avatar
Default ex bakes
Not bake but Brakes.............anyway what is a good brake pad to get that don't mind a little water and mud...........is it nessasary to change out the rotor if it has a few scars on it
Old Mar 20, 2005 | 07:31 PM
robbls's Avatar
Default ex bakes
A few grooves are okay... you just want to make sure the rotor is not warped.
Any sintered metal pad should work for you. RockyMountainATV.com has good pads on sale for $9.99.
It not hard to change the pads. All you need is a 12mm socket wrench and a C-clamp to push the piston back into the caliper.
Be sure to back off the stupid parking brake, if you have not already removed it.
Old Mar 20, 2005 | 07:37 PM
Dirtpig's Avatar
Default ex bakes
Thanks alot................I already have the brake block off............got the ez pull lever..like it alot better!!
RedGoblin
12
Apr 23, 2005 03:22 PM
coolguy8769
Nov 14, 2004 08:23 PM
mudAGoGo
Jan 30, 2004 10:07 AM
QuadBuster
Feb 8, 2000 10:30 AM
