mud removal
Old Nov 13, 2004 | 11:53 PM
coolguy8769's Avatar
Default mud removal
i have a powerwasher but wheni use it it rips decals and makes riples in the black fenders(look at pictures). using the straight hose doesn't have enough presure. what is there to get the dirt and mud of. and also what is a cheap way to get the dirt off that is baked on the engine?
Old Nov 14, 2004 | 01:23 AM
DuneRider650's Avatar
I ride a little here and there......
Default mud removal
ide also like to no this
Old Nov 14, 2004 | 01:44 AM
Outlawlawndragster's Avatar
Default mud removal
if it's baked on it's tough to get rid of but you can try this .
Bring up to operating temp spray area with a penatrating oil of some type even ATF then let it cool and try a spray cleaner and then use your pressure washer just stay back a bit . Good luck
Old Nov 14, 2004 | 02:19 AM
buckshot4x4's Avatar
Default mud removal
I've had the same prob with the power washer. I know this sounded like work but the best thing I've found is to wet the bike down with a hose for a while, and try to get all the thick stuff off, and then get after it with a bucket of soapy water and your mom's best s.o.s pad (wouldn't recommend putting it back in the sink afterwards). Seems like the longer you keep hitting it with the hose the softer the mud gets. Good luck
Old Nov 14, 2004 | 01:06 PM
VelociRaptor350's Avatar
Default mud removal
I just stop by one of those quarter car wash places on the way home. The one by me uses filtered water and whatever soap they use is the ****, it will take dirt out of scratches on white plastics.
Old Nov 14, 2004 | 04:12 PM
ridinhigh's Avatar
Default mud removal
Try this...before you go muddin. Spray on Armor All, or Black Magic etc. But don't wipe it off, when you wash it the stuff will peel right off. No.....not the decals, the mud. If it even cakes on at all.
Old Nov 14, 2004 | 07:02 PM
1ShotScott's Avatar
Default mud removal
I use nice warm to hot water and for the enging just a wet rag.
Old Nov 14, 2004 | 07:06 PM
TrailBlazerguy250's Avatar
Default mud removal
acid for the mud stains on the motor
Old Nov 14, 2004 | 07:32 PM
Jibrille's Avatar
Default mud removal
If you want to spend the money you could take it to a Steamer/Mobile Hotwash. I'm not sure what it is called in the states, or if it is the same here. But they use many chemicals that can make an engine look new, removing any kind of burnt on oil or mud stain.
Old Nov 14, 2004 | 08:23 PM
ridinhigh's Avatar
Default mud removal
Does the acid mess up the plastic??
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
