Advancing Timing w/ aftermarket plate.
Old Sep 25, 2000 | 10:42 PM
H300F's Avatar
What would advancing my banshee's timing with a pro design timing plate do?? where will it add hp?
is it worth the money??
i am trying to get the most i can out of it without spending a fortune.
Old Sep 25, 2000 | 11:07 PM
Backcountry's Avatar
Advancing the timing will help with low to mid range power. More than about 6 degrees BTDC will begin to hurt your top-end performance, as the spark is firing as the piston is coming up and it will work against itself. Most people, properly jetted, can safely run 4 degrees advance on pump gas. You can also slot the holes of your stator mounting plate to gain the 4 degrees without having to spend the money on the nice PD one.
Old Sep 25, 2000 | 11:17 PM
H300F's Avatar
thanks for the reply, what do you mean by slot the holes, can i mess it all up if i do wrong?? And if i can do this it would be great because i need to save as much money as possible.
thanks
Old Sep 26, 2000 | 09:55 AM
There are three holes that the mounting bolts go thru. Take a dremel and elongate the holes so that the mounting plate can be rotated clockwise. It will only be about .250" of an inch. Leave plently of material at the ends of each hole, min. .125" Don't make the holes any larger in diameter, just slot the holes.
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jul 5, 2015 09:04 PM
D-Hagz
Jul 4, 2015 02:19 AM
