2000 honda recon no start
The first thing I would check is your switches. Make sure your key and engine kill switches are working properly. Then check the ground connection on your coil and a different plug.
It might be the CDI box, but check the cheap and simple stuff first.
Okay, did all that and still no start. will my friends cdi box off his 2000 400 ex work? they look the same and atleast we could rule the cdi box out. looking ast a diagram of the ignition, theres the coil and magneto still left to check. anyway you can check these without replacing them?
thanks guys,
blackturbo
thanks guys,
blackturbo
Originally posted by: nate11
icant even get my 400ex to start i lost the key and i dont live near a dealer could i role start it
About your problem, when you say 'role start it' I'm assuming you mean push it as fast as you can and pop it in gear. I'm not sure how you are going to do that when you don't have a key. You still need to turn the ignition switch on so it will start and stay running. Remove the ignition switch from the machine, there are numbers on the back side of the switch, and find someone to make you TWO keys so you have a spare.
Jun 10, 2015 12:45 AM
