solenoid for winch yes or no?????
You do not need a solenoid for every winch. Most winches have them and some dont. Mine does not. The only thing a solenoid does is take the current and stress off of the switch so it does not burn up. Most switches can not handle large amperage but the solenoids can.
In most cases, your battery is located a long way from your winch. Any wire will have at least some power drop, the longer the wire, the more the drop. Plus a winch needs a heavy wire which is expensive and a pain to run. A solenoid solves this problem. It is just a switch that connects the big wire, triggered by a light wire. Plus, if a problem occurs, it is a lot cheaper to replace a solenoid than the winch motor. So, you don't HAVE to use one, but it's smart. Keep in mind too, there are different kinds of relays. Most are momentary relays, like on a starter motor. Its only meant to be on for short periods. It can get hot and draws a lot of power if used too long. Then you have latching relays that are for extended use. They have a mechanism that locks them in the on position until the switch is turned off. The latter is best if you really plan on using your winch heavily. Naturally, it is also more expensive.
