Adjusting Carb Float
Old Mar 22, 2005 | 02:16 PM
JimJa's Avatar
Default Adjusting Carb Float
From where on the carb is the carb float level measurment taken? I believe my '03 500i float adjustment is 17mm, but I don't know where to take the measurment, or how that measurement is taken (carb inverted/upright/etc?). Is there be any difference in the float setting based on altitude?
Thanks -
Jim
Old Mar 22, 2005 | 06:31 PM
Bluethumb's Avatar
Turn the carb upside down so the float is seated. You should use a depth micrometer to get an accurate reading. With the float bowl off, take a machinists ruler (steel ruler) and lay it across the carb. From the bottom of the rulers' edge just touching the float should be your 17mm. This is how I was instructed to do it, but ya never know I could be talkin ' out my ***.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 22, 2005 | 09:45 PM
garrett5462's Avatar
do u have a service manual? if not, u can find one on ebay for like 5 bucks.
Old Mar 23, 2005 | 12:22 AM
Bear4570's Avatar
Carb inverted. Measure from the flange on the carb where the bowl seats, to the top of the float(really the bottom). A ruler and your eyeball will get it close enough. The US measurement is .67", that's right between 42/64ths and 43/64ths. If being off by less than a 64th of an inch causes a problem, something else is wrong.
Old Mar 23, 2005 | 12:58 AM
JimJa's Avatar
Thanks to all. And yes, I do have a manual, but the instructions are not definitive. I don't have a problem but am doing some re-jetting and wanted to check the float while the carb was apart, and set it correctly. I've done float adjustments before, but each is a little different in the details. Your instructions clarify.
Jim
Cole Hadden
Jun 15, 2025 09:05 AM
skinnyr6
Aug 25, 2023 02:18 AM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
