2-stroke piston with exaust port?
Old Sep 26, 2000 | 04:32 PM
AL300EX's Avatar
can anyone explain how to drill my own piston, the advantages, and does this mod add power??
Old Sep 26, 2000 | 04:42 PM
retro's Avatar
I drilled holes in my Pro-X to allow more lubrication and cooling at my exhaust port I think. Just look at a Wiseco and make identical holes, about 1/8" diameter, 2 or 3 will do. Make sure there are not any sharp spots sticking out from drilling.
ERIC
Old Sep 26, 2000 | 04:49 PM
AL300EX's Avatar
how do you know were to drill the holes
Old Oct 2, 2000 | 05:02 PM
Backcountry's Avatar
What are application piston are you drilling??? If it's a two stroke, with a bridged exhaust, then this is what you to do it to. Assemble the top end without gaskets, leave the head off, and don't install the circlips, just pin the piston(w/o rings) in place and slide the cylinder over.
Take a "Sharpie" permanent marker and now outline each side of the exh. bridge on the piston skirt. When you disassemble, you'll have a nice outline in which then to place your holes in.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
