Polaris Reverse Override
Old Mar 25, 2005 | 01:34 PM
quebert00's Avatar
Default Polaris Reverse Override
Does anyone have instructions on how to override the reverse override switch? I would like it so that I don't have to hit that button any longer.
Is it just a wire ground that needs to be done?
I have an 04 600 Sportsman. Let me know.
Thanks
Old Mar 25, 2005 | 01:37 PM
XtremeSkier's Avatar
what do u mean any longer? like do u want to remove it?
Old Mar 25, 2005 | 01:39 PM
95sport400's Avatar
Do a search on here. This has been a popular topic. You'll find all the info you need.
Old Mar 25, 2005 | 04:58 PM
silverbullet2005's Avatar
what you have to do is get a four pin 12volt relay, and some 6" pieces of wire with the colors listed below. solder the wires to the relay terminals listed to the correct color wire. put heat shrink over the soldered terminal to seal from water/moisture. remove the gauge pod and locate the wires shown, you will have three brown wires(brown/red, brown/white, brown) find the all brown wire and make sure it isn't one with a stripe. the purple wire should be purple with a white stripe on your machine, this is the one which gets spliced to the "purple wire". I used scotch locks to attach the relay/wires to the factory wiring but am going to remove them and permanetly splice/solder them on and I cut the wires and added a four wire connector also cause with the mod installed you nolonger have control over the yellow button to change the trip/tach/hours display. this way I can disconnect the mod for the summer and connect it for the winter to plow. but you can decide what to do for yourself. I will try to take pics of my kit when I get home, I am in canada right now for work so I'll be home monday evening.
Relay terminal #30 connect to Polaris brown wire
Relay terminal #87 connect to Polaris wire gray/orange
Relay terminal #86 connect to Polaris wire red/white
Relay terminal #85 connect to Polaris wire purple
Old Mar 26, 2005 | 01:25 PM
Enganear's Avatar
Easiest thing to do is use a tie-strap to keep the button down. That way, all you have to do is slip it off if you ever want the normal functionality back.
Old Mar 26, 2005 | 03:05 PM
HELLHOUND's Avatar
Don't see the bennefit or understand why anyone would wan't to dissable this function as it was put there for safety reasons also how hard is it to push a button in for a second
Old Mar 26, 2005 | 03:55 PM
ZMan079's Avatar
If you ever get a nearly 800 lb machine stuck in the mud, up to the frame in snow, or just plowing, it is nice to have power to all 4 wheels without havin g to try to push or pull on the machine, and not have to push the button too. Just 1 time will change your mind, but that is just my 2 cents..... In fact I am looking at modding mine this week ....
ZMan079
Old Mar 26, 2005 | 10:52 PM
tyler711's Avatar
Couldnt you just put a switch on the override circuit, so it was like holding the button down? And when you wanted normal functionality, just turn it off?
Old Mar 28, 2005 | 02:24 AM
ZMan079's Avatar
Tyler711,
Yep with a few small work arounds it is possible, in fact I just came back from the garage where I just completed the Reverse override and 3 Head light mod an my '03 700. I just need to get some permanent sealed switches mounted now.....
Here is some info on those mods over at the Frontier. Snowride is the guy to talk to over there, he'll hook you up with the goodies for the override and 3 light mods
ZMan079
Old Mar 28, 2005 | 03:40 PM
tyler711's Avatar
So zMan, would just putting a small switch in place of (or in addition to) the existing override switch work? Off for normal operation, on for override (with no odometer function changing when on)?
