Polaris Reverse Override
#22
My hub fluid needed changing this winter, so plowing was easy, it stayed in AWD even with the button out. To get it into 2wd I had to rock it between rev and low a few times and the hubs would release. That wasn't that bad, it was still safe. But it won't get you unstuck.
#23
This is what I ended up doing. I just put a toggle switch in between the red/white wire and connection #86. That way I can turn the relay off an on when needed. I did this because on an 04 when doing this mod the button will always be 'down' and I still wanted the button to function as normal.
Relay terminal #30 connect to Polaris brown wire
Relay terminal #87 connect to Polaris wire gray/orange
Relay terminal #86 connect to Polaris wire red/white
Relay terminal #85 connect to Polaris wire purple/white
This is the switch I used.
http://www.acehardware.com/product/i...ductId=1296511
Thanks for all the help!
