Head light
Old Mar 26, 2005 | 10:13 PM
MaineiacDS650's Avatar
Default Head light
Has anyone else had a problem with breaking your head light where it mounts? How much does a new head light cost. I have a Baja and I was wondering if it was even worth buyig another one?
Old Mar 26, 2005 | 11:56 PM
DaBomb650's Avatar
Default Head light
Does the '03 have the new style headlamp (plastic) or the old (glass). Mine is glass, it hasnt broken, but the mirror backing inside has turned black, come off or something. Now my head lamp is about 1/2 the brightness it used to be.
Old Mar 27, 2005 | 12:22 AM
jackass650's Avatar
Default Head light
try searching the old posts for headlight and there will be all the info you need including part numbers and prices good luck
Old Mar 27, 2005 | 08:12 PM
ds650ratrider's Avatar
Default Head light
my baja broke a tab off the lense when my son slow rolled it. I just JB welded it and its lasted for the last two years.
Old Mar 27, 2005 | 10:09 PM
VEGAS650's Avatar
Default Head light
I've broken 4 headlights so far.
Three off the 00 and one on th 03.
The 03 still uses the glass one.
Old Mar 27, 2005 | 10:11 PM
Default Head light
Thanks ratrider I am going to try the JB weld.
Old Mar 28, 2005 | 01:27 AM
Default Head light
since the joint is hidden, I globbed it on real good and didn't worry to much about visual appearance.
Old Mar 28, 2005 | 02:11 AM
BajaX04's Avatar
Default Head light
A new 04 style headlight (2 bulbs in it) is plastic and very very cheap...$44 bucks! Another DS showered me with rocks and put a crack in mine. So it was a cheap fix. Now, there is an issue with putting this style in the older models. You have to order the newer bracket, cant be much more than $10. The $44 gets you the plastic light housing, bulbs, and the new single plug to dual "Y" short wire harness. To make it look right, you may want the color exterior ring (comes in like 4 colors now) and its also cheap like $6. If you have problems getting these prices try parkeryamaha.
Plus that glass light looks old now next to the newer clear lens style of the 04 and newer.
Old Mar 28, 2005 | 08:43 AM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
Default Head light
jackass
I see you found away to get my custom icon. Robert
Old Mar 28, 2005 | 08:34 PM
jackass650's Avatar
Default Head light
yes i did basicbajax hope you dont mind? lol
Divergent12
Dec 30, 2017 08:33 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Bulgin88
Aug 1, 2015 06:39 PM
ScopeZ_
Jul 28, 2015 01:44 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
