Help, I cannot get it started!!!!!!!!!!
Old Mar 30, 2005 | 10:27 PM
4willer's Avatar
Default Help, I cannot get it started!!!!!!!!!!
I recently purchased a 2001 DS650 and it had been stored in a garage for about 6 months. I drained all the old gas and replaced with new, charged the battery, checked the plugs, and checked all the fluids. I tried to start it but it will not start. It will turn over and but will not run. I tried spraying some starter fluid in the air intake and it fired right up but will not stay running. After running the battery down several times and using the starter fluid I thought the new gas would eventually clean out the carb but it still will not run. Although it is an 01 it only has about 15 hrs run time. I bought it from my brother and he bought it from a dealer. Any suggestions would be greatly appreciated.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 30, 2005 | 10:29 PM
03TRX300ex's Avatar
is the gas on. is the kill switch on run
Old Mar 30, 2005 | 10:34 PM
4willer's Avatar
yes and yes. I even disconnected the tubing comming from the tank into the carb to ensure the gas was flowing.
Old Mar 30, 2005 | 10:39 PM
gabesworldsds650's Avatar
check plugs again they may be fouled from trying to start it . also try and bypass your kill switch it may be bad, test your battery it may be no good it might be original if you can get 3 years on a ds battery you are doing someything that you need to share with everyone!! and once they start going bad they run funky
Old Mar 30, 2005 | 10:49 PM
Dser's Avatar
Not sure why everyone is suggestiong electrical fixes. If it runs when you spray starter fluid in it sounds like the electrical is fine. It's not getting fuel for some reason. Take the carb off and disassemble. Clean it. Make sure all the holes are clear. Sounds like it's gummed up from sitting. Maybe the float is stuck and not letting gas into the bowl.
Old Mar 30, 2005 | 11:58 PM
bombdsbaja's Avatar
DO NOT USE STARTER FLUID. well, that and go ahead and clean the carb I would bet that is where your problem is.
Tom
Old Mar 31, 2005 | 12:30 AM
mudnuri's Avatar
Tom
Yikes! What he said!
Old Mar 31, 2005 | 09:32 AM
4willer's Avatar
Thanks for the advice. I will give that a try and see what happens.
Old Mar 31, 2005 | 10:10 AM
Dser's Avatar
Instead of starter fluid I use WD40. It works well and has oil in it so it doesn't wash down the cylinder walls like regular starting fluid. I do this with my 2 strokes. Didn't think starter fluid would be a problem with 4 strokes though.
Old Mar 31, 2005 | 11:09 AM
Doctorturbo's Avatar
GOT BOOST!
The carb is clogged. Take it off and do a clean job on it. Starting fluid is fine; not a good idea to use it on a 15:1 motor though. [img]i/expressions/face-icon-small-wink.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
