500 ho pilot screw?
Old Mar 31, 2005 | 07:38 PM
braveops's Avatar
Default 500 ho pilot screw?
i forgot which way to turn in or out to richen it?[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 31, 2005 | 07:51 PM
SPORTSMAN70003's Avatar
Screw it in to lean it out screw it out to richen it.
Old Mar 31, 2005 | 09:01 PM
braveops's Avatar
thanx
Old Mar 31, 2005 | 09:43 PM
jefffoxsr's Avatar
My question is how the heck do you make the adjustment. How can you get a screwdriver on it where it's located. everything is in the way. What's the trick? Mine is too RICH right now.
Old Mar 31, 2005 | 09:48 PM
I usually take my carb off to adjust it. It's kinda a pain in the butt. Some people use a small bendable screw driver.
Old Mar 31, 2005 | 10:48 PM
braveops's Avatar
i used a screwdriver insert that has a double end and turn it with my hand u dont have to take it apart.i got lucky with mine no plug covering the screw
Old Mar 31, 2005 | 11:25 PM
zerowick's Avatar
My 600 is almost perfect but still has a tiny bog at the bottom, however, with 1/4 choke during warm up it has no bog at the bottom at all and responds awesome. Does that mean I still need to richen the pilot? Another thing, sometimes, when warmed up, after climbing a long hill with a loaded trailer and I stop and turn it off it makes a very soft back fire out the exhaust. These are minor issues, but I just need to know if I can make it better. Thanks
Old Mar 31, 2005 | 11:37 PM
If you pull the choke out and it helps then you are pobably lean. A back fire is also points to a lean condition. You might richen the pilot a little and see if it helps.
Old Mar 31, 2005 | 11:44 PM
zerowick's Avatar
10-4, I turned it out about a third after the update had been installed so I probably just need a bit more.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 1, 2005 | 09:23 AM
jimk72's Avatar
For adjusting mine I use a apex insert that is a regular screw driver and just put white chalk on one side to see how far I am turning it. It is only about 1/2 inch long so you can reach up in there with it without taking the carb out.
