Quadracer won't start
Old Sep 27, 2000 | 10:08 PM
LTqracer's Avatar
i have an 87 lt250r that wont start. yesterday i was riding it as about 1/2 throttle and it died. i was low on gas so i thought that i had run out but there was still some in the tank. today i put some gas in it and tried to start it but it wouldnt start so i changed the plug and it was covered in oil. i kicked it a few more times them i changed the plug and once again it was covered oil. with the new plug in i kicked some more and a few times it backfired like a gun. i hope one of you could tell me what is wrong with my quad. by the way about a month ago i got a new piston, rings, cylinder sleeve, and crank case. this is the only problem since.
Old Sep 27, 2000 | 11:43 PM
slickster's Avatar
Hiya,
It could be any number of things. Stuck reeds... Faulty ignition. Make sure you have spark by touching the electrode of your plug to the frame.
Put in a fresh plug... Stick it in 5th gear and pull in the clutch. Let someone pull you to about 30-35mph and see if it will pull start. It may just be that your cylinder is so flooded you can't kick it fast enough to get it to fire up.
It's so tough to diagnose a problem via a forum.
Old Sep 28, 2000 | 04:24 PM
THEXOTIC1's Avatar
Sounds to me like the bike was flooded. let it sits for a couple of mins and then try it again. Sure enough the bum start will get it going. As for the gun sound my LT500 does that when i start it up.
Old Sep 28, 2000 | 11:11 PM
lt250rman's Avatar
Same thing happend to me turns out it was the ignition.Follow the spark plug wire up to the black box looking thing, wiggle the wire alittle bit.After I did it to mine it started in one kick!
1991 Lt250r :
Ceet seat cover,DG alloy front bumper,DG alloy rear grabar,DG alloy nerf bars ,Emgo bars,Pro design kill switch,Maier plastic(Looks awsome I put lots of cool stickers on it),Uni air filter,Shockwears,Parking brake block off,RTC clutch lever,Motion pro twist throttle(took a while to get used to!),Leager A arms ,Ohlins front shocks(got them with the quad the look kinda old),Homemade motor skid(from speed limit sign),Turf tammers on back,IPT hole shot up front,And probly other stuff to but I cant think of all of them rite now. Please go to www.screaminglt250r.homestead.com
Old Sep 28, 2000 | 11:41 PM
bansheepower's Avatar
The same thing happen to my buddy's removed the side cover and take off your stator, it is probably rusted to hell, use brillo or steel wool to get rid off al the rust, and check all off your points, good luck with it
no not the stator, it is the fly wheel i am sorry i dont know wher my head is, good luck
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
chrisjack
Aug 21, 1999 04:52 PM
