Need information about sprockets for 350 raptor
Old Apr 2, 2005 | 03:38 PM
SNOTROD15's Avatar
Default Need information about sprockets for 350 raptor
I recently purchased a 350 raptor and the only thing that I dislike is that It seems that I am shifting through 1-3 gears so quick. How can I change this? Should I change my sprockets and what does most people change their sprokets too? 12 tooth on the front and what on the rear? What does the Raptor come with stock? I enjoy trail riding but having plenty of power when i need it and I dont wanta take too much speed away...
Hopefully you can help me out..
Scott
Old Apr 3, 2005 | 10:00 PM
rolsmojave3's Avatar
i'd go up one on the front...that should help out
Old Apr 25, 2005 | 09:07 AM
YFZRyderMace's Avatar
Well Scott, a friend of mine owns a white/red 350 raptor. The stock gearing is a 12tooth on the front and a 38 on the back. IF you want more power then you need to drop a few teeth in the front or go up on the back. But if you want more speed you need to do the opposite. But if you dont like that you are going though the gears quickly i would recomend you gear it up a tooth or two in the front this will take a little away from your power but it will give you more top end and it will cut down on over all wheel spin. My friend that owns the 350 geared his up 4 teeth on the front. It would run with a Z400 at top end but the excelleration sucked badly. SO i wouldn't recomend going up that far. So i hope you can take what i just said and find the information you need.
Jamie
bmxatv10
Oct 14, 2022 06:23 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
buddieboy
Dec 9, 2016 05:50 PM
Sassinm1
Sep 30, 2015 04:23 AM
black_thunder
Sep 22, 2015 07:59 PM
