LT80 Oil block off line, how to remove?
Hello, Can anyone tell me how to remove the line going from the oil pump to the carb? I had Jack do my motor and I no longer use the oil injection. I want to completly remove the pump and the line. Do you know what to do about the hole in the carb where the line comes out of once I do remove the line??? I looked at the specs and they call it a clip but I cant figure out how to remove the line without fugging somthing up. Thanks for your help eveyone!
When I done that to our LT Jack had sujessted to just cut the line and plug it with a tooth pick. I cut ours about an 1 1/2" from the carb and used a twisted shank brad to plug it. Or, You might try using a vacume line plug on the carb.
ALike mentioned, a rubber vaccum plug from the auto parts store works well.
The oil res. can surely be removed. [img]i/expressions/face-icon-small-smile.gif[/img]
I use klotz R-50 in Jacks motor at 32 to 1 ratios. Jack also likes torco gp-7 . What is it you are looking to do?
Uptmor250r
Uptmor250r
house1
Aug 9, 2015 10:49 PM
