what kind of fluid??
Old Apr 5, 2005 | 10:19 PM
besmallz's Avatar
Default what kind of fluid??
i have a scrambler 400 and i need to no what kind of fluid i put in the tranny. not where the dip stick is but where the shaft goes out for the front wheel drive.
Old Apr 5, 2005 | 10:23 PM
MaineMudder3's Avatar
So you meen your front gearcase? If so then its Polaris Atv Gear Lube, its in the smal 8oz bottle and is golden in color. Make SURE you get the gear lube which is golden color and not hub fluid which is green as both are in the same type bottle.
Old Apr 5, 2005 | 10:29 PM
besmallz's Avatar
im not sure but the rear sproket it right behind it and i think someone mentioned to me AGL fluid or soemthign like that
Old Apr 5, 2005 | 10:46 PM
I'm confused, you said not where the dipstick is for the tranny, but where the front drive goes out? Then you say the rear sprocket is behind it which would refer to the tranny? Please be more specific...
Old Apr 5, 2005 | 11:01 PM
besmallz's Avatar
there is a dipstick on the engine for the gear oil and there is a bolt to put some sort of a tranny fluid in by the rear sprocket and the shaft that goes off for the front wheel drive
hueby
Nov 6, 2015 11:34 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
