Front end binding???
Old Apr 6, 2005 | 09:41 PM
tpalm5's Avatar
Default Front end binding???
Hey guys, yet another sportsman 600 problem!! Whenever hit a bump with the left front tire something binds up. I just can't seem to pin down the problem. I think it could be a loose strut banging against the frame mount, differential, or cv joint. It seemed to start occuring right after I changed the front diff fluid. So, I changed it out with ATF and it still occurs. Has anyone experienced this? Thanks again, you guys are a great help!
Old Apr 6, 2005 | 10:21 PM
rebeloutlaws's Avatar
same thing here with a 700 sportsman it is the cv joint
they are about 200 dollars at the dealership but check out J R GRAHAM POWERSPORTS WAREHOUSE
www.jrgraham.com i got mine thru them for 78 dollars
this is --- 700polaris **also if you want pm me i will give you the guys name i talked to
tyler
Old Apr 20, 2005 | 04:20 PM
tpalm5's Avatar
I'm finally getting around to fix my quad but just want to make sure this is the right thing to order for the fix... REBUILD KIT . Also, is the repair something I could do or do you need special tools to do it / bring to a professional? thanks
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
