help on A-arm bushings please..
Old Apr 7, 2005 | 07:13 PM
lepper's Avatar
Default help on A-arm bushings please..
My 88 trail boss.. yadda yadda... anywhoo.. i'm tearing it down.. last thing to do is remove the a-arms and bushings so I Can send it off to powder coating right?????
Well..... How the heck do you get them suckers out?
Drill? torch???? They desperatly need replacing..to the point that it could have been bad if I road it anymore!! but we will fix that.. so advice?? thanks!!
dave
Old Apr 7, 2005 | 08:46 PM
Ridinghard's Avatar
It is just like the Scrambler and Sportsman, unbolt them at the frame and the strut. The bolts both go into a single shaft so you need to undo them at the same time, or it just rotates inside sometimes.
http://216.37.204.202/polaris_oem/Po...=13&A=111&B=27
Gives a blow up view of the A-arm.
The parts aren't too expensive so cutting the bolt could be an option as long as you have a way to get the bolt out after, or plan to buy a new shaft.
Sorry, I checked a 98 not an 88! May not be right for yours!!!!!
Old Apr 7, 2005 | 10:44 PM
Freedom500's Avatar
Like others have said, the metal bushing through the A-arm is one shaft. The trick I use when taking the two bolts out is to take one bolt all the way out, thread a nut onto bolt 1, then put the bolt back in the bushing at least six full turns then tighten the nut against the frame. At this point, it should be easy to take bolt 2 out of the A-arm bushing without the bushing turning.
Next, use two wrenches to break the nut loose, then take bolt 1 out. The A-arm should fall off if the balljoint is off.
Old Apr 7, 2005 | 11:04 PM
lepper's Avatar
okay A-arms are off the wheeler..
one bolt broke.. [img]i/expressions/face-icon-small-sad.gif[/img] and on the other side one was striped out.. someway you can replace the insides? or I Guess that would be the bushings correct???
and best way to get them out of the metal framed a-arms?
d
Old Apr 7, 2005 | 11:10 PM
Ridinghard's Avatar
ronnies
I just bought a new shaft for mine. This is a link to the 98 I had looked at before,they have 90 and newer but you can call too.As for getting it out, just push it out. May need a long screwdriver or something to push it with, but it does come out.
Old Apr 8, 2005 | 01:38 AM
lepper's Avatar
your linky no workie..
d
Old Apr 8, 2005 | 06:09 AM
Ridinghard's Avatar
Sorry, it was one of those pages that looks at cookies to know what you wanted.
online diagrams-ronnies
Have to search for yours but this will work.
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
