UPDATE! UNISON 90 NO SPARK!
My son rode it around it friday for about an hour and a half after we got it, and I started it sunday for about 5 mins and pulled the plug to check the color and it would not start back up. Went an bought a new plug and nothing. Checked the gas and oil they are fine.
The atv only has at most 2 hours on it, what is going on. HELP ME PLEASE!!
Thanks
Roman
Thanks
Roman
No Spark could be caused from:
- Dirt / crud within the ignition key, kill switch or other areas.
- Bad Spark Plug Cap.
- Bad Spark Plug Wire.
- Bad Ignition Coil.
- Bad CDI.
- Bad Stator. To test Stator, see below...
As a suggestion, start from the stator and troubleshoot towards the Spark Plug.
With a digital ohms meter, pull the stator output wires and test for ohms readings. For pictures on how I tested the stator on our Pred-90, surf:
Tool I used:
http://community.webshots.com/photo/...82501537yRsUQe
http://community.webshots.com/photo/...62613589PYiCcV
Wires on our Pred-90:
http://community.webshots.com/photo/...84460963PvEogV
http://community.webshots.com/photo/...84461583taUohN
Ohms Readings:
http://community.webshots.com/photo/...84444555dgMNXk
http://community.webshots.com/photo/...84444182nXeEcj
Note: At the bottom of each picture, select "View Full Screen" in order to read the small text.
Notes:
1 - Entire test can be done under 10 minutes (if you have a Digital Meter).
2 - Only physical work is unplugging the wires. These plugs are under the steering column area.
3 - The Ohms Reading values on your brand of mini will be slightly different. But, the verification formula of (approx.) A = B + C is the same. If you get a "ZERO" reading on the values, then your Stator is shot.
If you can, perform this quick "Stator Output" test and let us know the results.
Hope this helps.
- Bad CDI.
Tool I used:
Ohms Readings:
Notes:
Hope this helps.
Would say it's probably got something to do witht he plug wire. Too much of a coincidence.
Did you remove the cap off the end of the new plug? Make sure you didn't bend or break anything in the boot?
Check the fuses too.
Originally posted by: defcon5
Thnaks for the quick reply spike, will check when I get home from work. Could this really happen on a brand new atv? thanks Roman
As Raptorlegs stated, it could even be a simple spark plug cap problem. Could even be a bad connection that came apart. Or, even the fuse. Check all connections and its fuse. If possible, apply 12V electrical grease (dielectric grease) to each joint / connector while under the hood. If still "no go", then start from the electrical source and work downward.
If you've reached your max troubleshooting skill level or "had enough", then perhaps it's time for your dealer to get involved??? Hopefully, your mini is still under warranty.
Hope this helps as well...
Ya it's still under warranty as it's only 1 week old. How many fuses should i have on it, I have checked the one under the seat is there more to be found.
Thanks for the replys guys, is there anything else.
Thanks
Roman
Thanks
Roman
Check for spark at different grounding points of the motor? I have checked at easy to reach places and have gotten bad results. Against case under oil tank has given best spark. Not to emply but, this has happened to me, did you check that fuel was on? Will idle for awhile before running out of fuel. My son had turned the fuel off, had to use some choke and crank longer then I would think to start again. Probably not related to your problem but, I have read in other posts about running another larger ground from battery to frame. Not sure if this is a brand specific problem/fix or not but can't hurt any of them. I would also cycle all switches a few times.
Well I went and bought a multi meter today, and I don't have a clue on how to check even after what you guys have told me!
Mabye I will just get another Yamoto!!
Thanks guys
Roman
Thanks guys
Roman
