NO DASH LIGHTS,START,4WD????
Old Sep 28, 2000 | 11:43 PM
Quadracer4's Avatar
I hit a small stream today,all lights, everything gone no 4wd nothing dealer says some sensor???
Help
Old Sep 29, 2000 | 02:43 AM
Dazed's Avatar
I will put money that you need a new speedo unit try one of your buddys ride betcha everything works then.
Old Sep 29, 2000 | 04:40 AM
polcat2's Avatar
good call, Dazed. Ride'em hard Polcat
Old Sep 29, 2000 | 04:30 PM
Quadracer4's Avatar
Sorry guys, it was late last night when i posted it and i forgot to tell yall that its a 2001 scrambler 500
Old Sep 29, 2000 | 09:34 PM
CHICKENman's Avatar
QUAD just suggestion as this happened to my SP but under the hood I had knocked two wires loose and had same lose as you.CM
Old Oct 2, 2000 | 11:13 AM
kevin_staton's Avatar
If this happens out on the trail, check the key in your ignition to make sure it is on all the way. The key can turn back slightly and disable all the electrical systems except the ignition.
Could be worth a check.
whitty
67
Feb 24, 2021 02:52 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
1000gade
May 27, 2015 12:37 PM
trx430ex
Nov 15, 2000 01:26 AM
