85 honda 200s piston kit by wiseco
Old Apr 8, 2005 | 09:58 PM
paulie86's Avatar
Default 85 honda 200s piston kit by wiseco
hey i'm new at this whole forum thing, but has anyone tried the wiseco .50/65.5 mm oversize bore kit for thier 200s? it is about $92.00 and i was wondering if i get it would i have to do any other mods to the engine for it to work besides bore the head to 65.5 mm. is getting the head bored really expensive? any help would be great thanks!
Old Apr 9, 2005 | 12:19 AM
Rexkarz's Avatar
Increasing the bore that amount isn't considered a "mod", just a way to get a worn cylinder back to square. The head in this case does not need to be bored, but it may need rebuilding. A 200s cylinder bore should run $50-$100. Get the piston manufacturer's specification for clearance, bring it and the piston with you when you get it bored. Even better is to have your machinist measure your cylinder first and have him recommend the piston size. For a performance increase you might consider a higher compression. Just not too high, remember, you have a pull start![img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 9, 2005 | 12:49 AM
paulie86's Avatar
thanks for ur help, im going to talk to some buddies for some descent local machine shops. i guess its still ok to bore it out while i rebuild the top end right... even if nothing is wrong with it? it will help responsiveness correct? i was also thinking about a fmf exhaust
Old Apr 9, 2005 | 04:25 AM
Rexkarz's Avatar
Going up a point or two in your compression ratio (200s stock is about 8.5 to 1) should up the HP by about 25%. A pipe should add about 7-10%, If you change the pipe, go a step or 2 up in the main jet, otherwise it will just lean out and run hot.
As to responsiveness, it helps if your compression is low, but going higher in compression is free power!
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
95wolv
Jul 17, 2015 08:13 PM
timster911
Jul 13, 2015 01:57 PM
