Cann't Shift
Old Apr 9, 2005 | 11:19 AM
Winkle's Avatar
Default Cann't Shift
I'am having problems shifting my 2001 Lakota. Some times it takes me two or three times kicking it to get it to shift.
Is it my chuch or am I gust not hitting the right rpm.
Old Apr 10, 2005 | 08:29 PM
holeshotz8436's Avatar
sounds like the ajustment is off, to ajust it take off that plastic cover on the crank case and you should see a nut and bolt. loosen the nut, tighten the bolt till it gets hard then loosen it till it gets hard and then screw the nut back on and tighten it but hold the boltwith the screwdriver when you are tightning the nut orelse it will move
Old Apr 10, 2005 | 11:46 PM
Vunit's Avatar
yeah holeshotz is probably right, give that a try and see what happens, also all lakota's have bad clutch and they get even worst when you start modding them. I try to adjust mine ever few months or so, and i seems to be holding up fine even with all my mods. At first when my lakota is cold it's hard for me to shift but once it warms ups its fine!
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
