air pressure
Old Jan 2, 2000 | 12:30 PM
dan.t.'s Avatar
should the diameter of my tires( oem 400 explorer)be the same? i have the recomended pressure and the tires aren't equally 25" tall. would this cause drivetrain wear?
Old Jan 2, 2000 | 02:12 PM
mattsibley's Avatar
ok, on any atv tire, they usually will not be the actual hieght that is on the tire i.e.- 25 26 or 27 inches tall. So if you are running stock tires or any other tires for that matter and the diameter is what is recommended then you are ok. On my honda 300 the stockers were 23, and 24's. When I bought my vampsI bought 24 and 25's. You have to keep the stock ratio but if I had put 25's all around there might have been a possible problem, simply because on the stock bike it had a 1 inch smaller tire on the front than on the back? You got that, I know it was kind of confusing, let me know if you need anything else.
Matt Sibley
1999 Honda 300 4x4 Vampires, Lift Kit, 2500lb WARN winch
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
