85 200x kick start fix
Old Apr 12, 2005 | 10:46 PM
HARLIE's Avatar
Default 85 200x kick start fix
The kick start on my 200x skips alot. I split the case and found no worn gears or anything like that. Im assuming the problom is with the inner spring. I stretched it a bit and machined a 1/8 in spacer to put between the c-clip and spring retainer to add a little preasure. It worked great far about 50 or kicks now its back to skipping again. Does somebody have some advice for me?
Old Apr 13, 2005 | 01:56 PM
catchmeifucan's Avatar
yeah....get a new one.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 13, 2005 | 01:57 PM
And welcome to the forums!
Old Apr 17, 2005 | 09:46 PM
dragracer789's Avatar
I just started to split my case today for the same reason. Ill pm you if i find whats wrong...
Old Apr 17, 2005 | 09:58 PM
HARLIE's Avatar
thks dragracer... when i took mine apart nothing looked wore. The only thing i can figure is the spring lost tension and is weak. I just ordered a new spring but im not going to tare down till i find out for sure.
Old Apr 19, 2005 | 01:16 AM
Well it turned out to be two of the gears in between the two case halves. They were missing a few teeth, so I figured that would make it skip somtimes. I Put in extra gears I had for a spare motor and it works fine now... but in your case it could be the spring like you think,.
Old Apr 26, 2005 | 09:53 AM
GlennJ's Avatar
This is one weak spot within the 200X. Let us know how it turns out.
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
4trax300ex
Jul 29, 2000 11:41 AM
