Timing advance ?
Old Apr 13, 2005 | 09:53 AM
SPORTSMAN70003's Avatar
Default Timing advance ?
To anyone that has advanced your timing did it hurt your top end?
Old Apr 16, 2005 | 02:09 PM
Anyone?
Old May 3, 2005 | 01:33 PM
BMP's Avatar
BMP
We have seen on some machines where too advanced ignition will actuall slow the machine down on top end. Usually these are in the 5-7 degree range on race fuel. If you keep it 1-3 degrees advanced it shouldnt have much effect on top speed, you may actually gain a little more because it will rev a little higher.
Old May 16, 2005 | 02:58 PM
scramblered's Avatar
as the the timing advance is up,the peak rpm point decrease,as you make
retard timing,peak rpm increase,so it wouln't worth to pass that point
if you known the rpm for sure.
Old Jun 23, 2005 | 03:23 PM
ATVnRocks's Avatar
Advanced my 03700 by adding weld to the flywheel, & filing down to match the profile of the pick-up "bump". Had to add fuel to the pilot circuit though, also running a 42mm BSR (wrong choise of carb). Long story short, I can whip a stock 800 in the top.
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
rcappie4
Jul 10, 2015 04:54 PM
D-Hagz
Jul 4, 2015 02:19 AM
