I think i did something bad today.
Old Apr 14, 2005 | 04:13 PM
Parkerman's Avatar
Default I think i did something bad today.
Today i changed all my oils and i think i did something bad. I stripped out the rear gear case plug. Its not the threads on the plug iuts on the gear case. Any sugestions. I put some pipe thread tapp on and it screwed in alright but i will have to see if it leaks. If it does i think i might just tap a bigger thread and just put in a bolt. Any sugestions. Why wouldnt thay make the plug strip before the acual gear case. Just makes me sick. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 14, 2005 | 04:17 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I have done that before too. I went with the next biggest size and tapped it out. if you put grease on the tap the chips will stick to the tap. Im would still flush it out with solvent before filling with oil.
There is also a thing called a "boatplug", Its a rubber expanding plug that will seal the hole.
Old Apr 14, 2005 | 04:54 PM
thewayout420's Avatar
you can always use a heli-coil also..
Old Apr 14, 2005 | 04:56 PM
Parkerman's Avatar
What is a heli-coil?
Old Apr 14, 2005 | 05:36 PM
this is a heli coil..
Old Apr 14, 2005 | 09:40 PM
garrett5462's Avatar
tap and die it out, on size bigger and put a nuton end of bolt
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 22, 2015 12:19 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Anomers
Aug 16, 2015 11:06 AM
mdigitale
Aug 6, 2015 12:35 AM
