Looked everywhere, can't find 24x8x10 front mud tires
I checked all I know. Please, only links to this size. The problem is the 10" wheel size. I can find them in 24 & 25 " tall but will have to go to a 12" rim. Anyone? Thank you for checking.
Thats because no one makes that size. The only size in a front 24" would be on a 11" or 12" wheel. Thats why I said the only way to do that size is to go with the Magnum 12" wheel. Otherwise your stuck with the 23x8x10 tire. I dont think it makes a difference to go with the rear tire 1 size bigger seeing that the rear needs help with clearance. I dont have any problems with rocks on the front.
I had the same problem, I bought a set of used wheels and tires off a sportsman. The rear wheels are useless to me but the front set of 25x8x12 gave me great font end clearance. Put the rear tires on my wheels and now have good ground clearance. Bought them off ebay, the key is the 12in. wheels for the front. You'll find the 12in. tires have a greater variety.
Originally posted by: Lukester
95sport400,
Thank you for the reply. No, I have 23"s for stock and want to go taller.
95sport400,
Understand. I will go taller in the back too. I just thought I would put this out there in hopes of a 24" tire on 10" wheels before spending on the 12" wheels. I've kept my I open for some used 12" wheels for the front but haven't found a good deal. I'm looking to do it on the cheap to make the cost bennefit worthwhile. If I have to go to 12"s up front (appears the only way), I'll go up to 25" front and 24" on 10"s rear and drop a tooth from the front sprocket. 2manytoys, Thanks for your patience - just had to double check.
If you're looking for a mud tire, try Interco Tire. They have a 24x9-10 that fit without rubbing on my old 91 Trailblazer. It's also available in the Vampire series as well.
