edelbrock carbs????
Old Apr 20, 2005 | 12:01 AM
fast700rappy's Avatar
Default edelbrock carbs????
what do you guys think about them on a yamaha raptor are the good or bad need new carbs don't wana spend a bunch of money if I don't have to
Old Apr 20, 2005 | 05:16 PM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
A set of stockers setup correctly will out flow the edelbrock. The edelbrok cant keep up on a modified raptor engine. 35mm FCRs will fit the stock boots. 39's are the way to go but require an intake setup.
I dont know much about LRD big bores but they (LRD) should be able to reccomend a set up for you.
Craycraft http://www.14mins.com/craycraft_racing.htm
Kenz http://www.kenzcycletech.com/
Barker http://www.barkersbars.com/
All these are at the top of the game with raptor engines and would be able to give you accurate info and prices.
Old Apr 20, 2005 | 11:05 PM
duneittilludie's Avatar
The stock carbs are what i run on my high compression 690 with LTE duals and they do a very good job.From what i have experienced and what i have seen others do i can tell you that the stock carbs do not work well with anything over about 180-185 mains(mikuni) without being modified for flow.I may switch to the grizzly needle jet set up for running bigger mains but after finally getting my 690 to run well i am hesistant to mess with it.I am using 175-180 mikuni mains with all other carb components as they are stock.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
