rubicon transmission
Old Apr 20, 2005 | 12:32 AM
angler's Avatar
Default rubicon transmission
I was wondering which mode do you for top speed D1 or D2?
Old Apr 20, 2005 | 01:53 AM
RSeb's Avatar
D1 for speed. D1 is designed to keep the engine's RPM in the peak HP range, D2 keeps RPMs in peak torque range.
Old Apr 20, 2005 | 09:53 AM
angler's Avatar
Which one should be used for pulling?
Old Apr 20, 2005 | 09:17 PM
500rubicon's Avatar
If your not towing too heavy of a load you can keep it in D1 but if your towing a lot of weight just use low.
Old Apr 20, 2005 | 09:29 PM
mudblaster's Avatar
if you put it in low its auto or manual the d1 or d2 dosent matter.
and if its auto its is set for max tork and power because its in low.
Old Apr 21, 2005 | 12:21 AM
Specta's Avatar
Each time we have reached our highest speed we were in ESP.
In D modes, the transmission is capable of achieving overdrive. I would have to think if the trans were to go into an "overdrive" you could reach a higher speed in D2 seeing how the trans runs the engine at a lower RPM. By the time, as an exapmle, the engine reaches 4000 rpm it should be going faster in a higher gear.
Old Apr 21, 2005 | 10:57 AM
SuperMike2233's Avatar
I'm like Spectra...it goes faster in ESP. D1 has just a hair more torque than D2...or at least D1 gets my tires goin just a hair better. D2 is for "loose traction" situations...like gravel
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
