SP 700 Speedo & No AWD
Old Apr 20, 2005 | 04:39 AM
Moosetang's Avatar
Default SP 700 Speedo & No AWD
I have a 2004 Sportsman 700. I loose the AWD from time to time. The speedo is working but the battery indicator light on the speedo keeps flashing. I have load tested the battery and it is good. Everything else on the speedo is working "except" when on diagnostic mode the volts shows only 1.0. I have checked the volts with an external volt meter and it is showing 12.4 and 14.3 when the bike is running. The dealer say that they took the speedo out and tested it in another bike and it does the same thing.Battery light still flashes. They took a new speedo from a new bike on the floor and put it in mine and guess what the battery light does not flash and everything works fine. He says the speedo head is shot. After reading all the post on this forum this seems to be a problem with the Polaris machines. "Always owned Hondas Before" So I don't want to shell out 350 plus bucks cdn for a new speedo when it most likely won't last more that a year. IS THERE A WAY TO BYPASS THE SPEEDO TO KEEP THE AWD WORKING. Has anyone else had this problem and found a workaround. Surely with all the speedo problems that these machines are plagued with someone must have found a fix other than throwing more money away.
[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 27, 2005 | 11:24 PM
kentuck's Avatar
I have 3 used speedo"s for my 02 700 twin in my shop i will sell ya for a reduced price.
last one cost me $ 209.36 u.s.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 27, 2005 | 11:34 PM
rmkcac700's Avatar
Ive never seen an issue with SP speedos, I fix these things for a living, not any issues, but they can fail, Ur dealer should be going back to polaris and having them replace it under GOOD WILL. that bike is new enough, they should have no problem with a good will claim. It should not cost u at all.
Old Apr 28, 2005 | 12:17 AM
JJonJon's Avatar
I've always heard since I got a Polaris how they dont hold up, they're cheap, and how they aren't dependable. Well i've had my 04 SP 700 for over a year and EVERYTHING still works the same from the day I got it. I abuse it too. My AWD works great and i've never had any sort of problem with the Speedo. But good luck Moosetang.
2004 Polaris Sportsman 700
'27 ITP 589 M/S
3000 lb. Warn Winch
2001 Honda Rancher ES (For Sale)
2.5 Warn Winch
Old Apr 28, 2005 | 04:26 AM
Moosetang's Avatar
Well we bypassed the speedo so hopefuly we will have no more trouble with the AWD.
Old Apr 28, 2005 | 04:59 AM
jimmypsp700's Avatar
The Hall sensors fail often but the speedo is a diff story, although i have heard of some problems with that and the AWD, mostly the older models.
Jim
speedbuff
13
Nov 11, 2020 10:16 AM
black_thunder
Sep 20, 2015 10:21 PM
Adrian Turner
Aug 30, 2015 04:08 PM
bradco
Aug 21, 2015 08:11 PM
Xpedtion4254x4
Dec 20, 2000 12:58 PM
