Throttle safety switch on 350L
Old Apr 21, 2005 | 10:29 PM
doofixer's Avatar
Default Throttle safety switch on 350L
Can I just cut one of the wires comeing out of the throttle so the darn thing will go in reverse. Im tired of messing with the adjustment. It seems after I get the cable adjusted its fine for a while then it needs to be played with again. Sometimes it will go in reverse without dieing and sometimes it wont. Anyone got a way to bypass the safety bs.
Old Apr 21, 2005 | 10:34 PM
BigDog800EFI's Avatar
The two wires in the throttle are both needed. One goes to the carb the other goes to the oil pump.
Old Apr 21, 2005 | 10:37 PM
doofixer's Avatar
Gotta be a way to bypass it. I have it adjusted now so it wont die when I let off the gas,but it wants to die when I try to put it in reverse.
Old Apr 21, 2005 | 11:40 PM
drlang's Avatar
Have you tried pressing the reverse over ride button when you are having problems? Look long and hard at that before cutting anything.
Old Apr 21, 2005 | 11:47 PM
doofixer's Avatar
Im positive its in the throttle,reverse override works good when I can put it in reverse without it killing. Its that little button under the throttle cover with the 2 wires going to it.
Old Apr 22, 2005 | 07:23 PM
drlang's Avatar
I didn't ask how it worked when you get it in reverse. Have you tried to press the reverse over ride at an idle? Does the bike idle weird? Try the button when you try to go into reverse.
Old Apr 22, 2005 | 09:45 PM
I was wrong. I was refering to the cables. Sorry not sure on the wires.
Old Apr 22, 2005 | 09:57 PM
doofixer's Avatar
anyone know how to bypass the switch on the throttle?
scram5050
Aug 30, 2024 01:39 PM
skinnyr6
Aug 25, 2023 02:18 AM
user493
Aug 13, 2015 12:54 PM
Captjay
Jul 23, 2015 12:33 PM
skeets44
Jul 17, 2015 01:04 PM
