Tranny on SP600
Old Apr 22, 2005 | 10:25 AM
cjr854234's Avatar
Default Tranny on SP600
Hey guys, I got a 2004 SP 600 I've noticed that when I start to drive forward in High gear at about 2000 RPM and in Reverse around 800-1100 RPM I can hear a klunking noise coming from my tranny. I had this problem when I first bought the fourwheeler but the klunk only happened when I was going downhill and my *** end hopped off a rut I was told that it was normal because of the automatic and EBS. However it's beginning to do it on flat surfaces and I'm concerned. Anyone have any suggestions?
Old Apr 22, 2005 | 05:59 PM
Riderbob's Avatar
Cjr
I had the same complaint when I bought my 600sp.
I had the dealer trade my secondary clutch for the TEAM clutch from a 700 EFI. That took care of a good portion of the noise. It is still there a little but quite a bit better.I did a little investigating and found that there was quite a bit of freeplay in the trans. You are bound to get a little noise just due to the amount of freeplay between all the components involved with the drivetrain. I also installed a heelclicker clutch kit. The kit comes with a new secondary spring(silver)That also seemed to make the "clack" quieter(or I might be getting more deaf or just used to the noise). It also improved the EBS.
Hope this helps
Rider
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
DOAinNY
Jun 12, 2015 02:26 PM
mpcop077
Jun 10, 2015 08:30 PM
