2004 Rancher ES Shifting Problems
Old Apr 22, 2005 | 09:43 PM
Wild2day's Avatar
Default 2004 Rancher ES Shifting Problems
my gear light just blinks and wont let me shift,however it shifts with the emergency shift lever,not very well i would add.it will blink what gear you in but will not shift automatically with shift buttons.....thanks for any advise i would help anybody else out if i could.........Wild
Old Apr 22, 2005 | 09:56 PM
pat89's Avatar
Check to see if you shift button contacts are clean, if not that may be your problem.
Old Apr 22, 2005 | 09:58 PM
Wild2day's Avatar
i was really tring to figure out what the blinking senquence was and what to do to fix......thanks
Old Apr 22, 2005 | 10:05 PM
jamesNC's Avatar
I had the same problem and there is a thread in here somewhere describing the problem, and solution. You have a faulty angle sensor. I have heard that Honda had a problem with the supplier and has since switched. I replaced mine, even though it would have been a warranty item, just so I wouldn't lose my machine for however long they needed to keep it. It is very easy to change; at the lower front of the engine, you will notice a round cylinder and below that a rectangular cover that protects the sensor. Two bolts for the cover and two for the sensor. Unplug the old sensor and plug in the new. $35 and 20 minutes. If you have any questions, feel free to ask.
Old Apr 22, 2005 | 10:07 PM
jamesNC's Avatar
Oh and BTW, the other thread has the blink sequence error codes. Yours should be three. Have you checked your machine for the recall notice on the front tie rod ends?
Old Apr 23, 2005 | 03:41 AM
Wild2day's Avatar
Well that seems to sum it up. I believe that i will try that as well.Now i'm going to look for those codes.as i would like a printout to have for future........Thanks a heap I would gladly return the favor if i could......happy trails..............
Old Apr 25, 2005 | 04:28 AM
HondaHoosier's Avatar
Dude, I bought my 04 Rancher ES in October and last week , I had the same problem, I called the dealer and was told it was the angle sensor and that it is becoming a common problem with the ES, easy fix, replace it $42.00. Other than that no problem and I ride it very hard
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
Gtsordo
Jul 13, 2015 10:38 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
