WOLVERINE DIFFERENTIAL FLUIDS?
Old Apr 25, 2005 | 11:33 AM
PERM01's Avatar
Default WOLVERINE DIFFERENTIAL FLUIDS?
Is regular 80w90 fine or should you run yamalube in the front and rear diff.?
Old Apr 25, 2005 | 12:24 PM
95wolv's Avatar
Any good gear oil will work, I would run a GL - 5 rated lube (for limited slip differentials), remember,you have a clutch pack limited slip in the front, so go to an auto parts store and get a bottle of limited slip additive, and put an ounce in the front, then fill the rest of the way with the GL 5 lube. The additive will prevent sticking and damage to the front diff clutch, and make it handle and steer better and last a lot longer. I have heard of a lot of guys complaining of noise and stiffness in the front axle after a lube change, the additive will prevent that.
Old May 25, 2005 | 01:49 PM
badasskfx700's Avatar
i would use 80 90 fliud thats wut i used and i havent had any problems i would use wut the manufacture reccomends so that way u dont mess up ur 4
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
hueby
Nov 6, 2015 11:34 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Polaris5
Aug 29, 2015 09:11 PM
