Flipped!!Little water in airbox, and oil. 400ex
Old Apr 25, 2005 | 08:57 PM
wheelinforlife's Avatar
Default Flipped!!Little water in airbox, and oil. 400ex
My 400ex was upside down in a little pond for like 10 sec not to deep but... i know i should change my oil. But what should i do with my air filter? I'm letting it air out. What can i clean it with? Did i damage my motor at all? Another thing I noticed my back left tire wobbles. I look at it and when i wiggle the tire it is loose by the red hub part conected to the axle. What they hell can I do here also. Thank you
Old Apr 25, 2005 | 09:10 PM
whitebroskfx440's Avatar
ok change your oil dry your airfilter turn off your gas and stand your quad up so the fuel drains out incase theres any water in the carb. take off the wheel and on the hub should be a looks like a bolt with a cotter pin in it take the pin out and tighten it put the pin back in mount the tire and ride it
Old Apr 25, 2005 | 09:18 PM
Do you think that back tire being loose could have been killing my acceleration and top speed?
Old Apr 26, 2005 | 12:41 AM
Old Apr 27, 2005 | 02:35 AM
quicksilver's Avatar
I was with a buddy and we tried to drive across the missisippi river by towing his 400ex ( I was riding) with his forman 450es ( he was riding)
the ex was over the seat in water and i just kept the clutch in and the throttle up . the 450 drifted off the sandbar and went under the water, locked up and stalled. the ex stayed running until the airbox filled with water and then locked up too. we used another good quad another friend was riding and towed both out of the water and emptied air boxes and pulled spark plugs. had them both running again in a half hour and both still run fine to this day. good times.
so there shouldnt be anything wrong with yours, since our ex was submerged for almost an hour until we got it pulled out.
Old Apr 27, 2005 | 12:20 PM
REDEX300x's Avatar
when you are in deep water never stop hitting the gas [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 27, 2005 | 12:29 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Unless it is over the intake. If water gets in your engine, your going to have to change your oil very frequently for a while. My buddy lost his 250X down a river once, he changed the oil every little ride about 5 times and cleaned the carb really good. It still runs today. If your oil is still milky after a couple changes, keep changing it!
Old Apr 27, 2005 | 12:32 PM
REDEX300x's Avatar
i meant when you are in the water ...ofcourse u need to change oil if water leak down to ur enigne
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
