sprocket flange removal
Old Apr 26, 2005 | 02:09 PM
warmdye's Avatar
Default sprocket flange removal
Anyone replace thier 400ex axle? How'd you press on and off the sprocket flange?
Old Apr 26, 2005 | 04:40 PM
cezar21's Avatar
gently beat it with a ruber malet
Old May 8, 2005 | 01:05 PM
warmdye's Avatar
Rubber mallet definetely does not work. May have to take it to the dealer.
Old May 8, 2005 | 03:08 PM
quad2xtreme's Avatar
I've used a piece of heavy pipe about 3-4 feet long that has an inside diameter larger than the axle. Slide it over the left side of the axle (the side that would be the same side as the battery if installed in the bike). Lift the pipe and throw it down at the sprocket holder. You can get a big flat washer to protect your sprocket holder if you are concerned about nicking it.
/Jon
Old May 8, 2005 | 05:34 PM
warmdye's Avatar
thanks i'll try that
Old May 12, 2005 | 04:18 PM
cezar21's Avatar
use some liquid wrench that stuff can break or help break anything lose
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
