Fuel Gage Problem
Old Apr 26, 2005 | 11:05 PM
erikd5155's Avatar
Default Fuel Gage Problem
I have a friend who has a 05 Artic Cat 500. He ran it really low a bout a week ago and has filled it full but the gage is still reading Empty. Any ideas?
Thanks for any replies!
Old Apr 26, 2005 | 11:22 PM
jwoodsman's Avatar
Sounds like the float in the tank is stuck, reach under the tank and give it a smack with your hand .
Good luck
Old Apr 27, 2005 | 12:45 AM
Bear4570's Avatar
I usually just slap the side of the tank next to the gauge, sometimes several times and works everytime.
Old Apr 27, 2005 | 05:06 PM
JimJa's Avatar
The gauge is held in the tank with a rubber gasket. Carefully pry under the gauge with a flat screwdriver. Do a little at a time, working around the assembly. Don't over do it or you will break the gauge. Once it pops free, lift the entire assembly out from the tank.
The float slides up and down on two guide rods. As it does so it rotates a twisted piece of flat metal, in the middle, between the two guide rods and in the center of the float. As this twisted metal piece turns, it moves the gauge, giving you the fuel reading.
Obviously the float is sticking, probably on the guide rods. Spreading them apart just enough to release the binding should fix the problem. You'll see where the problem is occuring.
When installing, use silicone on the gasket or you'll never get it to snap back in like it's suppose to.
Old Apr 27, 2005 | 05:17 PM
DirtDoc's Avatar
A while back all the gauge parts within the tank fell apart. Anyway, after rebuilding the gauge, I found installation was easy by simply placing the rubber grommet (gasket) in the tank first, then push the gauge down into that. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 27, 2005 | 05:35 PM
frndinalowplace's Avatar
my 03 400 has the same problem. but after taking the gauge out and looking at the slide, i can tell its definitely not the slide thats sticking but the red needle and shaft inside the gauge face. im just gonna buy another one.
Old Apr 27, 2005 | 05:44 PM
Lonnie104's Avatar
Hay thanks, I was the guy with the problem. I took the sending unit out and it had came a part and broke a wire off. Put it all back to geather and works fine now.
Thanks All,
Lonnie
Old Apr 27, 2005 | 08:33 PM
erikd5155's Avatar
Well Lonnie you told me you could not read or write? That is why I posted this message for you. You are a turkey. If you are reading this look at my profile (erikd5155) and look at the guy in the red shirt doesn't he look like a turkey would you trust him? Just joking Lonnie is my best buddy we have pretty well grown up around the fire dept. we both started on Honda 110’s in the early 80’s. We are friends for ever! Well that is if he doesn’t **** me off or anything.
Thanks for all the replies!
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
