Warn Contactor Location?
I have a Warn 3.0ce on order and saw some old threads about the Warn contactor location. Is the general consensus that contactor should be installed under the hood to keep it dry? I am also going to be using the Kappers Fabricating winch mount.
Anyone have some underhood mount pictures of contactor when they had it taken apart?
Thanks!
Treacherous
Thanks!
Treacherous
I've had some recommendations to mount it next to the EFI ECU below the light pod.
Anyone do that?
For those that mounted in tool compartment...did you mount to the side of the compartment or the bottom of the compartment?
Thanks!
Anyone do that?
Thanks!
Top front towards gas tank, still gives my a lot of room in there and makes it easy to get to if needed.
I ended up mounting under hood. If it turns out to be a bad location I will move it. :-) I moved the fuse block slightly to the left and was able to mount just to the right of fuse block. I drilled new holes for both.
I'll take some pictures for others before I bundle it all back up. Preliminary test tonight has the winch working. I just need find a place to mount the remote control plug.
Treacherous
Treacherous
Jeff Roper
Feb 1, 2022 11:48 AM
Oct 10, 2015 10:20 AM
