Warn Contactor Location?
Old Apr 28, 2005 | 10:22 PM
Treacherous's Avatar
Default Warn Contactor Location?
I have a Warn 3.0ce on order and saw some old threads about the Warn contactor location. Is the general consensus that contactor should be installed under the hood to keep it dry? I am also going to be using the Kappers Fabricating winch mount.
Anyone have some underhood mount pictures of contactor when they had it taken apart?
Thanks!
Treacherous
Old Apr 28, 2005 | 10:48 PM
20045SP500HO's Avatar
under the hood to keep it dry ... LOL ... i clean under my hood offen, it's always packed with MUD! I like the new mounting location next to the battery ... easy to clean.
Old Apr 28, 2005 | 10:56 PM
Do you have yours mounted with that Polaris mounting bracking next to the battery? Just trying to get some ideas since I have heard everything at this point.
Thanks!
Old Apr 28, 2005 | 11:00 PM
I shouldn't have LOL shame on me ... yes i mounted mine next to the battery and my rear winch's is mounted to the back on the tool box.
Old May 1, 2005 | 10:08 AM
DSLKSL's Avatar
I mounted mine, under the seat in the tool compartment. Stays clean and dry and does not take up much room.
Old May 3, 2005 | 10:38 PM
I've had some recommendations to mount it next to the EFI ECU below the light pod.
Anyone do that?
For those that mounted in tool compartment...did you mount to the side of the compartment or the bottom of the compartment?
Thanks!
Old May 3, 2005 | 11:51 PM
DSLKSL's Avatar
Top front towards gas tank, still gives my a lot of room in there and makes it easy to get to if needed.
Old May 4, 2005 | 12:04 AM
Seems EFI ECU takes up this space as see in this picture.
I'll probably have to utilize a rear location because of this.
Old May 4, 2005 | 02:44 PM
Deerkiller's Avatar
Hey,
i like the nerf bars, did you make them?
Had my 04.5 500 for a week and had the black plastic foot thing that runs between the fenders wrecked. $100.00 at the dealer
deerkiller
Old May 4, 2005 | 11:29 PM
I ended up mounting under hood. If it turns out to be a bad location I will move it. :-) I moved the fuse block slightly to the left and was able to mount just to the right of fuse block. I drilled new holes for both.
I'll take some pictures for others before I bundle it all back up. Preliminary test tonight has the winch working. I just need find a place to mount the remote control plug.
Treacherous
Jeff Roper
Feb 1, 2022 11:48 AM
EIF
Apr 20, 2017 07:15 PM
Oct 10, 2015 10:20 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
panicmanic
Sep 28, 2015 12:59 PM
