o/t: Modifing exhaust on tractor.
Old Apr 30, 2005 | 06:45 PM
extremerider2811's Avatar
Default o/t: Modifing exhaust on tractor.
is it possible to mount the current exhaust pipe from its horizontal position to a vertical posistion will i need a flapper for the top of the exhaust anyone know any place that sells exhausts for diesel tractors???
thanks alot
Old May 1, 2005 | 05:28 PM
tencubed's Avatar
Being retired is a hoot!
I suspect it can be done, you might have to cut a hole in the tractor hood or you may be able to run it outside of the hood. Take some measurements and talk to your local muffler shop about bending out the pipe you will need. You will need a flapper or 90 Deg. bend at the top to prevent rain from entering the engine.
Old May 1, 2005 | 09:37 PM
95wolv's Avatar
Runnings, Mills Fleet Farm, or any ag-parts store will have the pipe caps you are looking for, they come in several sizes for different pipes.
Old May 2, 2005 | 04:41 PM
TexasPsycho's Avatar
Are you talking about a small tractor that already has the exhaust out the side? My Kobota has the horizontal exhaust. The way it's exhaust was turned at the end it would cause hot exhaust to blow back on me while I was mowing, that made mowing 4 acres a chore in the summer. I just had a pipe bent to run my exhaust under the tractor. Might not be the same size your talking about though, it's a 25 horse (I think ?)
Old May 3, 2005 | 12:00 PM
mine is a 97 or 08 b7100 HST. 4 wheel drive its a 16 horse but it seems like much more because it has a 3 cylinder diesel in it, and yeah the exhaust already comes out the left side of the tractor pointing strait ahead i was wonder if i can move that to a vertical position, it has 4 bolts and a gasket it appears to be moveable and the pipe is not perfect strait its curved a little to the left but still rain could get in, but can i mount a flapper on that already stock exhaust. i'll try and find a site to show you what it looks like..
thanks.
Old May 3, 2005 | 03:56 PM
As long as the flange is the same at all four mounting bolts you can turn it with out any problem. The only thing is it will put the exhaust right at head level and it the wind is blowing the right direction you will get a face full of hot exhaust.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
