Polaris 425 magnum 4x4
Old Oct 3, 2000 | 03:48 PM
Mudd's Avatar
What happen to the Atv specification that told you about older Atv’s that was on this site? I am trying to find some information about a Polaris 425 magnum 4x4.
Old Oct 3, 2000 | 04:54 PM
MagnumMudMan's Avatar
Mudd
I am not sure about the specifications sheet you are talking about. I have a 98 Magnum 425 4x4. If you let me know what you want, I will look it up in the owner manual supplement tonight when I get home. If its general questions, fire away.
Old Jan 14, 2002 | 09:15 PM
tampavii's Avatar
Hi Guy
I can buy a 97 425 magnum for $2000.00
what do you think what are pros and cons about this quad
How does it handle need one for wife .
Thanks Gb in NJ
650 prairie
Old Jul 27, 2003 | 10:56 PM
nedrah's Avatar
Default Polaris 425 magnum 4x4
I have a polaris magnum 4x4. 425. On my headlight is has stamped date 01/01/1994. does this mean I have a 94 model. I am looking for a set of cv joints and having trouble finding them for a 1994.
Old Jul 28, 2003 | 09:48 PM
ftwflh's Avatar
nedrah -you have a 1995 425 Magnum.....Mudd - buy you a manual.But if you tell me what you are looking for I know these machines inside out.
Old Jul 29, 2003 | 08:21 AM
mtpockets's Avatar
tampavii
i bought a '95 Magnum425 brand new and it's been a terrific ATV. it's still in the family to date (i sold it to my brother in VT)
it has chain (not shaft) drive to the front and rear end. every oil change we check the adjustment. no problems.
this ATV receives severe abuse and neglect since i sold it to my brother and it hasn't skipped a beat! VERY reliable!
the only con i can think of is the lack of down-hill braking.(no EBS) i don't know if the newer Magnums have EBS but i like it on my Sportsmans.
it's fun to ride, stable, and reliable and your wife should enjoy it![img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 31, 2003 | 09:26 AM
nedrah's Avatar
Thanks for clarifying my year model. Could someone look at this link on partsland.com
http://www.partsland.com/index.cgi?N...T-NEAPCO-PARTS
I need cv joints for the front right and left. My axles are good. Could someone tell me which item I need to order. Thanks
Old Aug 27, 2003 | 05:18 PM
MrsChristy's Avatar
Well it sounds like you are the expert here. My husband and I could really use some help! We purchased 2 1995 magnum 425 4x4's this year. My husbands ran great until hunting season. (of course) His is acting like mine was after about a month of owning it. Both machines will cut out and sputter at a higher rpm, and somtimes even back fire. We could never get it over 25 without it sputtering. Mine is getting much worse now even backfiring through the carborator, putting on a good show including black smoke and dying. Eventually not wanting to start. It will turn over, but not start. We did get it to start after changing a plug that fouled out, and replacing a needle. But it still runs terrible. We went to the dealer in anchorage here and everyone offers suggestions, we try and nothing seems to work. The oddest part about it is that it seem to come and go. We have drained all of the gas, taken abart the carberator,changed a cockpit,and a needle. I would list everything that my husband has tryed, buy I dont remember it all. I just know that these have been a real pain and I am terrified to be stranded in the Alaskan wilderness with my two young children. Please if anyone can help it would be great!! Our last trip out was a nightmare, I forgot to say also that the rear susp. broke on my husbands machine so that is going to cost us about $300. so what ever help we can get will be great![img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Aug 27, 2003 | 05:42 PM
nedrah's Avatar
This should fix you. I copied it from a web page.
Override Button Override with a circuit board
This will allow you to have 4wd in reverse without having to push the yellow button. The process will also allow normal operation of the Reverse Light. NO CUTTING OF WIRES is necessary so that the quad can be returned to "stock" at any time.
Materials
12 inch piece of wire of same gauge as quad wires
4 female "push on" connectors as used on the circuit board
2 Schottky Barrier Diodes (Model 1N5821), Rated at 30 Volts Maximum at 3 amps
Electrical Tape
Patch Wire
1) Cut the piece of wire in half, attaching one connector on each open end. We will be using one connector on each wire as a holder for the diodes.
2) Take one of the wires and push the diodes (one at a time) into the "channels" in the connector. Ensure that the stripes are pointing in the same direction (the power will flow toward the stripe).
3) Take the other wire and push one of the connectors over the other ends of the diodes. What we will have is a length of wire with 2 diodes in parallel in the middle of the wire.
4) Then tape up entire length of wire clearly marking the direction the power flow.
Procedure
1) Find the Gray/White, Light Purple and Dark Green wires. These three wires come from the Override button and are in the same "bunch" of wires.
2) Disconnect the Gray/White and Light Purple from the board and install the Patch ensuring that the power flows FROM the Light Purple terminal TO the Grey/White terminal. Ensure that you tape up the connectors on the disconnected wires to protect them from shorting.
3) Disconnect the Dark Green wire from the board to disconnect the Rev-Limiter. Ensure that you tape up the connector on the wire to protect it from shorting.
You can now use the Override button to power an accessory . . . I have added a car horn to mine.
REV OVERRIDE BYPASS INSTRUCTIONS (TWO)
OK, these techniques to override the reverse rev limiter (yellow) button have been tried successfully on ’99 model Polaris machines without a circuit board. The headlight wiring modification will work on any Polaris with the three light setup.
From William Bashlor we have this method of bypassing the switch. Find the purple wire and the gray w/white stripe wire that comes from the override switch. Cut these two wires and connect them together so the switch is eliminated from the circuit. That’s it. This simple method, will however, leave the reverse indicator light lit up continually in both forward and reverse gears.
The method Jack Schulz employs is a little more complicated but allows the indicator lights to work as they were originally intended. Disconnect or cut the gray/orange wire coming from the speedo and you eliminate the reverse rev limiter. Find the purple wire and the gray w/white stripe wire coming from the switch (yellow button). Instead of cutting them, patch a 12v 20amp (minimum) diode between them with the power able to flow in the direction of the gray/white wire. This allows the reverse circuit to power the AWD while in reverse and does not allow the AWD circuit to power the reverse indicator light when not in reverse. This method leaves the yellow button hooked up so it has the advantage of allowing you to use it as it was originally intended in the unlikely event that the diode would burn out.
The method I use is a combination of these two, for two reasons. First, I want my reverse indicator light to function properly because that’s where I’ve connected the hot lead for my auxiliary back-up light. That way when I shift into reverse both the reverse indicator light and the back-up lights come on. Second, I wanted to isolate the yellow button from everything else so I could use it for a horn button. So I cut the gray/orange wire coming from the speedo to disable the rev limiter. Then I cut the purple wire and the gray w/white stripe wire coming from the switch (yellow button) to isolate it. Between the purple and the gray w/white stripe wires I installed the diode, with power able to travel in the direction of the gray/white wire. That completes the reverse rev limiter override, and now that it’s isolated, the yellow button can act as a momentary “on” switch for whatever you want to hook up to it. To hook up a horn simply patch a wire from a switched power source (like the cig lighter) to one of the cut yellow button wires (install an inline fuse if you wish). Then run a wire from the other cut yellow button wire to the positive terminal on the horn, and another wire from the negative terminal on the horn to a ground. Beep Beep!
I’d like to add a note here about the mechanical aspects of all this “cutting” and “patching”. As tempting as the ease of using a “Scotch Lock” type patching connector is, I personally would not trust anything like that in the harsh environment our machines often endure. The most reliable electrical connection you can make is with solder. To patch another wire into a wire without cutting it, the best method I’ve found is to cut enough of the wire fasteners and/or tubing necessary to get some slack in the wire you want to work on. Then grab it with a small mechanic’s hook and pull it as far away as you can from everything around it. Then I take a small butane torch (mine’s a little bigger than a cigarette lighter) and burn away the insulation at the point I’m holding the wire with the hook. Only about ¼” of the wire needs to be exposed. Tin the exposed portion of the wire with some solder, then tin the end of the wire you want to patch into it. Now just touch them and the tip of the soldering iron together and you have a solid, reliable electrical connection. I reinsulate the finished connection with liquid Plasti-Dip applied with a Q-Tip. This seems to go on thicker and set up faster than the liquid electrical tape, which is about the same thing. After the coating sets up resecure the wiring as possible. I’ll only mention the obvious danger of using fire around things that can melt or explode. Be careful there’s nothing you don’t want damaged in the path of your flame.
For three headlight operation I’ve had a push-button switch patched between the hot wire for my low beams and the hot wire for my high beams on four different Polaris machines with no problems, except for dirt and water occasionally fouling the switch. If you like you can just patch a wire between the two hot leads so that no mater if your switch is in high or low, all three lights will come on. The addition of the switch in this “patch” line just gives you the option of opening the connection so your handlebar switch can function normally. On most late model but pre-’99 Polarises you can fiddle with the OEM light switch in-between its low and high detents and get all three lights to stay on, but it’s not so easy on ’99 & up with the new switches. As I said, the addition of patch wire with an auxiliary switch will give you the option of getting all three to light up, but last week I tried a new idea and so far it’s worked flawlessly. Instead of a switch patched between the two hot leads I installed a diode. Actually, since I already had the switch there, on mine I just installed the diode between the two wires that go to the switch and left the switch in place. If the diode should burn out on the trail then I can still use my switch as a back-up to light all three lights. But after the diode worked so well on our “test” rides last weekend I really see no need for the switch. We had both our machines running with all three lights on, low beams powered through the diode, for many periods of up to an hour both Friday and Saturday nights without the slightest flicker or any other indication of malfunction. It was really nice to have only one switch to deal with for either the two low beams on low or all three lights on high. All you need to do is install the diode between the yellow high beam hot lead wire at the back of the pod headlight bulb and the green low beam hot lead that runs from the handlebar switch down to the low beams. The diode needs to be installed with the current able to flow through it from the yellow wire to the green wire. In addition to the diode you’ll need about a foot of 18 gauge wire (min) for your “patch” lead. Once you get the wire’s insulation removed in the proper places you can easily test which direction the diode needs to be installed by temporarily connecting it with alligator clips at each end (roach clips, for those of you in Rio Linda). This differs from the auxiliary switch method in that you will no longer have the option to light just the pod high beam alone.
For those who are unaware, a diode acts like a check valve, or one-way valve, in an electrical circuit. Current is able to flow through it one way but not the other. I bought the diodes I used from a place that rebuilds starters and alternators. Ask for one that is rated for 25-30 amps at 12 volts. Their appearance may surprise you. Because they’re designed to be pressed into a fitting on an alternator they look a little like a stick with a small cylinder on one end, or a tiny piston without the bearing collar on the crank end of the rod. The “stick” or “rod” is one terminal of it, anywhere on the sides or top of the “piston” is the other. Tin a dab of solder anywhere on these two points to solder the wires that will perform your “patch” between the hot leads. Once the diode is installed wrap the entire body of it with electrical tape to insulate it from shorting to a ground.
Just a word of caution here. Because of the amount of additional current draw I suggest you not allow the machine to idle for an extended period with all the lights on. I’ve made these modifications to more than one machine with success, but that doesn’t mean there won’t or couldn’t be problems in the long run from doing them. This info is provided strictly on a “what I’ve done” basis. I’m not encouraging anyone to do anything they may regret. That’s my disclaimer, so I hope you enjoy the mods as much as we do if you choose to do them. I’ll also try to help by answering any questions there might be via personal email, as my time p
Old Aug 27, 2003 | 05:47 PM
Farmr123's Avatar
1) check out the EBS adjustment
2) be sure the carb vent, and especially the gas tank vent are not clogged or kinked
3) check the fuel pump
4) check the spark plug, wire, and boot
This should be a good start, if none of this works, get a listing of what was tried & any other symptoms you have.
Farmr
