Atakk Hurricane 200cc Review
Old May 4, 2005 | 11:12 PM
atvofne's Avatar
Default Atakk Hurricane 200cc Review
Well This last sunday May 1st, My father bought a 200cc 4 speed manual atv. We allready have registered it and I have driven it in my yard intill saturday I get my permit. My frist thoughts where this things is gorgougs. It truely is. SO far that is. I have taken down the trail against parents rules and atv laws which I shouldnt have but it is my first atv and my brother was with me. The shocks worked well for 2 persons = 310 pounds to the dot even though the limit is 209. The shocks where bottomed out but the engine ran smoothly and didnt even bog going up a slighty high degree of an angle. The plastic is cheap as tawianian plastic gets but the engine is honda bluteprint engine and runs great. It is broken-in so I havent fullly pushed it to the full capactiy but i had it up there in 4th gear going well over 35 atleast 43 - 45 MPH. A bolt has come off but I am replaceing it tonight And will have it back on the plastic tommorow. The ground clearance in the back is one to complain about it is probaly 3 inchs the front is well over 5 inch's. The tires have wonderful traction. And will last me a while. This coming saturday will be the true test I will have my permit and will be going rideing with my friend with his 80cc pro tuned dirtbike and we will be going 10-20 miles that day. Once I break it in I will be purchaseing a K & N air filter and change the oil with the recommend 15-40 oil type. And I will be adding grease to all the a arms and movable parts. And adding fluid to the drive shaft if needed and a NGK Spark plug. Or clean the one installed now. I am new to these machines when will I know its brokend in how many miles? What noise? How many weeks im unsure. My friend said about 50 miles. I will also be posting videos and pics on my website through out the summer as I add stuff to it. Also how do I find the bolt pattern its 4 bolt but I want to find the space inbetween how would I do this. Also the diamiter of the exhaust pipe if I buy a new muffler I need to no the size? Jwing I will be posting many times in this thread about it. Overall for the price and value I give it a 10 out of 10 it is well worth the money! But I would like to find where Atakk is from what company. I heard Azuma not sure. Good Day BP Sorry for mistypes typed fast
Old May 4, 2005 | 11:15 PM
atvofne's Avatar
Ok the AKUMA's look just like the Atakks Same company different names for reselling value. So that question is answered. http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW Looks like that but mine is black with red front fan air filter cover.
Old May 5, 2005 | 07:21 PM
atvofne's Avatar
Today I cut the "Rocker" Style shifter down so it wont mistakenly shift into the wrong gear, I installed a high heat spark plug. Runs much smoother a few screws have fallen out replaceing this week. Also I need help finding the bolt pattern where would I do this? On the Tire? Rim? It has 4 bolts but I need to know the spaceing.
Old May 5, 2005 | 10:22 PM
atvofne's Avatar
** First Problem ** Well I put the idle up a bit as it was low and kept allmost stalling. After that I ran it for a few hours fine. Then I started running a little aggressive then stoped for about 30 minutes. Started again then I took it down the road maybe 50 yards and Went to put it down to 1st held the clutch It stalled. Im like o probaly hit the kill switch so i checked everything it was all ok. Put it in net. And try4ed to start wouldnt budge. So I reved it a little then tryed to start starts fine. Now The Idle is off and I cant seem to get it to work at an ammount of turns or postions. And I adjusted the throttle line still nothing. Should I take it to the dealer to fix? It is an engine probaly not a avarage wear problem. Or could I do this my self. ? Thanks in advanced.
Old May 6, 2005 | 02:06 AM
Scooter86's Avatar
Knows Old ATV Questions!
atvofne, slow down a bit to type, OK? I can barely make heads or tails of what you have written.
shimanok2
Jan 29, 2016 07:37 PM
01ssls1
Sep 22, 2015 06:50 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
Sep 10, 2015 01:56 AM
