Question about idle jet size if anyone cal help?
Old May 5, 2005 | 12:28 AM
jackass650's Avatar
Default Question about idle jet size if anyone cal help?
I have read posts in the past about if you are past 3 turns out you need the next bigger size idle jet well got mine good and running today and I started at 4 turns out turned it in half turn increments slow and it started to mis a little shut it off counted how many turns it took to seat it lightly which was 2 then turned it back to 4 turns then turned it out slowly in half turn increments till it missed a little then shut it off and turned it in til the needle was seated which was 7 turns so then i took 7 minus the 2 from the bottom and figured 5 turns divided by 2 which was 2 1/2 plus the 2 from the bottom it took to sputter = 4 1/2 turns from the lightly seated position it runs good now but my question is do i need to get the next bigger size idle jet to keep the turns down to 2 1/2 to 3? any advice thanks fellas
Old May 5, 2005 | 12:52 AM
JMAC650's Avatar
I was at 4 turns so I went with a 45 PILOT jet from the stock 40 and now I am at 2 3/4 turns out. It is not the starter jet it is the pilot jet just to confirm.
Old May 5, 2005 | 03:48 AM
jackass650's Avatar
did it make a noticeable differance?
Old May 5, 2005 | 04:11 AM
JMAC650's Avatar
I had a little backfire on decel and it cleared it right up.
Old May 5, 2005 | 09:59 AM
SCOUNDREL's Avatar
I have a 45 pilot as well. Don't ask me why I just do.......[img]i/expressions/face-icon-small-confused.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
hondarider1234
Jul 21, 2015 11:53 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
