Check your screen!!!!!!!!
Old May 6, 2005 | 09:20 PM
Cmymud's Avatar
Default Check your screen!!!!!!!!
I got a used 02 AC 90 a few months ago. Ran ok when we got it.
Then out of the blue it started to bog down then it would not run at all.
I would start great. Idol great, but would not move at all.
Well after
1.Going to pre mix
2. Playing around with the spark plug.
3. Cleaning the Carb.
Dang thang still would not move.
I called my dealer to tell him I was bringing it in he said, "Check the Screen in the Exhaust pipe"
Uhhh ok....... Well you guessed it. This thing is a rocket out of the whole (with the throttle screw all the way in)
When I first test drove it after cleaning the Screen I had the Throttle screw all the way out I it would lift the front tires up with me on it !!!!!
Clean Your Screen !!!!!!
Old May 11, 2005 | 12:55 AM
defcon5's Avatar
Good advice, thanks for sharing.
Roman
Old May 17, 2005 | 05:04 PM
Dynoport's Avatar
Just take it right out,i did on a 2005 Eton Viper 90R.
We ride on sand and gravel so no worrys.
Old May 17, 2005 | 07:42 PM
garrett5462's Avatar
same thing happened to my ttr, make sure you check at least a few times a year.
Old May 19, 2005 | 03:33 PM
scottso's Avatar
Now I'm going to sound stupid [img]i/expressions/face-icon-small-blush.gif[/img] - there is a screen in the pipe? Where is it, before the baffle? What did you do open the pipe and pull it out?
Old May 19, 2005 | 03:46 PM
Dynoport's Avatar
On the Eton Viper90R there's a allen head that you take out of the muffler and then use pliers to pull out the screen.
I think you can also do the same to the Arctic Cat 90.It's in the muffler(just take the baffle out) Arctic Cat also has a block in the carb and i think it even has a washer in the head pipe where the pipe meets the manifold(restictor)I here taking all this stuff out makes it really move.
Goodluck.....
Old May 19, 2005 | 03:55 PM
scottso's Avatar
I have looked at the exploded views of the Cat and compared it to my Kasea. The motor is identical. I see the brass restrictor in the carb and the washer in the exhaust manifold. I wonder about the the screen (guts) of the exhaust pipe though. Guess I'll have to check.
slowgsxr97
Mar 18, 2022 03:40 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
