steering creak
Old Oct 4, 2000 | 07:46 PM
Ursus's Avatar
My Recon has developed an annoying creak/squeak when I turn the handle bars. Seems that there is somthing that needs some lube of some kind. It seems to be coming from the bracket that holds the upper steering column to the frame. I ordered the service manual today but the noise is driving me crazy and I gotta do somthing. I don't want to use the wrong thing though and cause more damage then repair.
Old Oct 4, 2000 | 10:47 PM
bayou220atv's Avatar
My bayou 220 did the same thing. Grease every single stearing joint you can. and also grease the grease zerks on it. After I did that the sqeaking stopped.
Old Oct 4, 2000 | 10:48 PM
My bayou 220 did the same thing. Grease every single stearing joint you can. and also grease the grease zerks on it. After I did that the squeaking stopped.
Old Oct 5, 2000 | 01:20 AM
rl4wheeler's Avatar
where the front steering pivots in the frame is a seal and bearing. you have to pull these out and get the mud out of them and regreese them. when u get your manual it will show u how to do this it is not real hard to do. but that squeek can drive u nuts i know have been there. hope this helps.
Old Oct 8, 2000 | 07:34 PM
450FOREMANRIDER's Avatar
Hey I had the same problem with my 450 Foreman. All I did to cure mine was buy a can of WD 40. Spray everything that moves on the frontend and spray down underneath the handlebars where it goes down inside the fourwheeler. This cured mine.
2000 Yellow 450S Foreman 4x4 bone stock for now
Old Oct 11, 2000 | 09:46 PM
00HondaEX's Avatar
I have this same problem with my 400EX. It creeks real loud and the bars are unreasonably hard to turn. I have only had it for a 1-2months
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
