predator 50 throttle response
Old May 14, 2005 | 04:48 PM
Que4life's Avatar
Default predator 50 throttle response
can i get better throttle response, my daughter really has to apply a lot of pressure and then it jerks her
Old May 15, 2005 | 01:59 AM
defcon5's Avatar
I would call hetrick and ask about some clutch upgrades.
Roman
Old May 15, 2005 | 10:45 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
I would think a new carb and reeds would help.
Old May 15, 2005 | 03:33 PM
spike99's Avatar
To remove throttle control pressure, perhaps its OI system could be removed (and run Pre-Mix with proper ratio based on brand of oil), or a throttle extender could be used or perhaps the "pull springs" on the sytem could be exchanged with less compression springs???
Does it "jerk forward" because your young rider is either off or "full throttle" (like my daughter) or is because the carb's jettings needs to be tweaked a little better?? If spark plug is dark tan color in all throttle ranges and the thumb control pressure is "ok", then better reeds might be the answer.
Hope these ideas help as well....
Old May 15, 2005 | 04:43 PM
Que4life's Avatar
thanks
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
craacker
Sep 9, 2015 04:32 AM
Brandon400
Sep 7, 2015 12:20 PM
