HELP..SPORTSMAN REVERSE LIGHT ON IN LOW...
Old May 21, 2005 | 09:17 PM
polarisbear500's Avatar
Default HELP..SPORTSMAN REVERSE LIGHT ON IN LOW...
Maybe this new title will get more hits : thanks WGMARQ
1999 500- when in neutral, the reverse light is on too, when in low, reverse light is on and i have to use the override button to go faster than 2 mph, in high it is fine, in reverse it is fine. only neutral and low is the reverse light constantly on and causing the use of the override in low gear. please help.. thanks, PB500
Old May 22, 2005 | 08:19 PM
WGMARQ's Avatar
Maybe that wasn't the problem after all, oh well. Have you tried cross posting ?
Old May 22, 2005 | 08:28 PM
what do you mean by that?
Old May 22, 2005 | 08:33 PM
WGMARQ's Avatar
Changing the name on the post didn't seem to help get you an answer. Have you tried ATV Frontier someone there might be able to help.
Old May 22, 2005 | 11:35 PM
Grumpy2's Avatar
I had a 1999 Sportsman 335 that did the same thing. I turned out to be the switch in the shifter. Hope this helps
SyTye
Sep 11, 2015 02:45 PM
Pahuntman
Sep 5, 2015 11:07 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
