SP 500 HO Dial a Jet ????
Old May 23, 2005 | 11:14 PM
yankee's Avatar
Default SP 500 HO Dial a Jet ????
Does the carb on the SP 500ho have the float bowl fitting on the side to replace with the fitting that Dial a Jet supplies? Or, do I have to drill out the Hex Nut Drain plug on the bottom?
Thanks
Old May 23, 2005 | 11:27 PM
SPORTSMAN70003's Avatar
You don't have to drill it has a fitting you screw out and put the dial a jet fitting in.
Old May 24, 2005 | 02:50 AM
yankee's Avatar
Is that the allen headed screw on the left side (as you're sitting on it) of the carb of the machine?
Old May 24, 2005 | 12:17 PM
Yes its the allen head in your float bowl.
Old May 24, 2005 | 04:29 PM
yankee's Avatar
Thanks. Got it hooked up. Now I just have to play around and figure out the settings
Old May 24, 2005 | 04:32 PM
Good luck I could never get mine tuned in.
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
coolhuh
Jun 24, 2002 04:05 PM
sparkys
Jan 30, 2002 10:31 AM
