Sport Quads Discussions on sport quads.
porting with +4mm
Old May 24, 2005 | 11:09 PM
duvalbanshee1's Avatar
Default porting with +4mm
I have a stroker crank +4mm and my bike just have 65hp and I think my porting is not very good. Do you think that I need a special porting? please give me some links or pictures. thank you
Old May 26, 2005 | 09:23 PM
dragracer789's Avatar
If you had it ported for the stock stroke and try to put in a 4mm stroker it will not run worth a fu*k. You will have to have your cylinder re-ported for the right port timing for that crank.
Old May 31, 2005 | 07:18 PM
Bubba297's Avatar
It will also differ depending on whether or not you are running a spacer plate. The porting needs to be done by a degree wheel and also done to what type of riding and what pipes you are running. There are a ton of variables to factor in for proper performance. I am sorry, it's just not very cut and dry.Bubba
Old May 31, 2005 | 08:43 PM
untouchable350's Avatar
I agree with bubba the first question the technition will ask you when you want it ported is what pipe do you have.
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
