New Rubicon Snorkel
Old May 25, 2005 | 12:03 AM
CrazyJames's Avatar
Default New Rubicon Snorkel
Take a look at my Home made snorkel kit for my 2004 Rubicon. My Pics
Let me know what you think of it. Its not tested as of yet but will soon be.
Old May 25, 2005 | 10:23 AM
Cirviver's Avatar
Very nice job! I just made one for my 05' Rubi last night. I will have pics by this weekend.
The only things that I would suggest doing to yours is to make a bracket that u-bolts to the rack for strength. If you roll yours the way it is, the snorkel is going to break the front plastic where you cut the hole. I will post my pics in a couple of days and you can see how I did mine. You also need to run all of your vent lines (differential, brakes, radiator, etc) to the snorkel. If you don't run your vent lines, the water can get into your differential, brakes, etc. and cause you problems down the road. The way you have it now is going to be fine for running in deep water but I would still re-route the vent lines.
I put a snorkel on my old Fourtrax 300 and my buddy's Foreman 450 and they both worked great. You can ride with the handlebars under water and it will keep going. It is so cool to be able to go places where nobody can follow you!
Let me know if you have any questions about the vent lines.
Cirviver
Old May 25, 2005 | 04:31 PM
pat89's Avatar
Looks like a quality job! I agree with the bracket idea. Have you considered painting it black? You may want to check to see if you need to re-jet. I like it.
Old May 25, 2005 | 06:13 PM
CrazyJames's Avatar
I am planning on installing a brace for the pipe and rerun the vent lines also.....just have not done it yet. Thanks for the responces. Cant wait to see you pics Cirviver.
Old May 26, 2005 | 10:22 PM
Cirviver's Avatar
CrazyJames, I got a few pics of my snorkel added to my profile. I have not run my vent lines yet but I will have that done and post a few pics this weekend. Let me know after you test yours. I am sure that you will have no problems b/c it looks like you did a great job!
Cirviver
Old Jun 3, 2005 | 11:13 AM
Cirviver's Avatar
CrazyJames,
Did you ever make your bracket and test your snorkel?
I had mine up to the handlebars in water last weekend and it did the job without a problem. I crossed a pond and when I got to the other side, I took a look inside the airbox and it was totally dry!
I will suggest one thing that I had to do being that it is a liquid cooled motor. I put a switch between the thermostat and the cooling fan so I can turn the fan off when I enter water. Once you get into the water, the engine will cool and you don't have to worry about using the fan but you MUST remember to turn the switch back so that the thermostat can turn the fan on and off as needed. If you get into the water and the fan is running, it will burn up the fan motor b/c the fan tries to spin but it can't b/c of the water.
Let me know if you have tested yours. I hope that yours works as good as mine does.
Cirviver
Old Jun 6, 2005 | 06:00 PM
CrazyJames's Avatar
Hey guys......tried my snorkel. It worked GREAT!!!!! No water in the air box at all. I wish I had the camera to show you some pics. I am working on a web page for our local rides.....it is still under construction but you should check it out from time to time. Here is the home pagel ink : MSMUDDAWGS WEB SITE
Old Jun 6, 2005 | 06:41 PM
reliv007's Avatar
Crazyjames on the website I Cant wait for the videos!!!Will they have sound???[img]i/expressions/face-icon-small-wink.gif[/img]
Customer Service #1
May 15, 2020 08:46 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Steeldon
Sep 9, 2015 09:38 AM
